What parts to get??
rayward - 27/4/06 at 05:04 PM
after being tempted to the dark side, i'm going to fit a bike engine in my car(ST Locost) have sourced an engine, and can strip whatever parts i need from the bike aswell,have i missed anything from the list below??
Engine
c/w Starter/alternator/Throttle Bodies/injectors/fuel rail/throttle+clutch cables
Wiring Loom
c/w ECU/Reg rec/Coils/Clocks/Switchgear/Ignition switch+key/starter relay/fusebox/clutch switch/sidestand switch/sensors
Radiator with fan
expansion tank
Exhaust Headers.
Fuel Pump/Filter/Pressure Regulator.
Speedo Sensor
anything else that would be useful??
cheers
Ray
[Edited on 27/4/06 by rayward]
[Edited on 28/4/06 by rayward]
G.Man - 27/4/06 at 05:08 PM
starter relay, fuse box, all sensors for loom, side stand switch, clutch switch..
rayward - 27/4/06 at 05:16 PM
added to the list,
cheers
zxrlocost - 27/4/06 at 06:19 PM
youve listed most
switch gear will make wiring so much easier
as you know
fuel sender out tank otherwise youll get a fault code
G.Man - 27/4/06 at 09:46 PM
Really?
I never did... I am using custom pump and sender wired to car loom via ecu relay..
zxrlocost - 28/4/06 at 08:38 AM
my r1 gives a fault code if the fuel sender isnt plugged in
Hellfire - 28/4/06 at 11:34 AM
Depending which bike engine, you may also want the fuel pump. Some in tank pumps don't require a return feed
Phil
rayward - 28/4/06 at 06:06 PM
added those bits on too.
ta
Ray
