Ballpark Carb Setup
Ferrino - 23/6/06 at 04:23 PM
Started the R1 last week and the engine is idling pretty roughly (sounds fine when you rev it out of the idle circuit). What is the best I can do to get it in the ballpark before having it setup on a rolling road? I have already fitted a Dynojet kit, with ballpark needle setting and jet size (I guess this doesn't affect idle though).
Should I just set all mixture screws to 2.5 turns out (I have seen someone mention 4 is good though) and then synchronise carbs with the balancer I have borrowed?
Ferrino - 25/6/06 at 10:24 AM
OX - 25/6/06 at 05:30 PM
balance the carbs then do the mixture screws ,2.5 is standard and a little weak.
start on the left hand side mixture screw and turn out very slowly untill you hear the engine revs pick up a little then do the same with the other 3 screws.you might have to lower the revs with the tickover screw to get it back to normal tickover speed and then do all 4 screws again to fine tweek
Ferrino - 25/6/06 at 06:37 PM
Cheers OX! So when do you stop richening (ie. screwing out) the mixture - when the revs no longer rise?
RichieC - 25/6/06 at 07:01 PM
Interesting thread as Im having probs at the minute. Would be a good thread to become a "sticky" - R1 tuning for idiots type thing.
Hope you get it sorted
Rich
Coose - 28/6/06 at 02:49 PM
Mine was based on Richard Miles' rolling road setup ('01 motor, Allbikes design manifold, Pipercross filter, TTS kit).
Air screws out I think 3.25 turns, fit 144 main jets, raise the needles a notch and balance the carbs. Job's a carrot!
