Hi all.
What sort of oil pressure you guys are reading?
After starting to warm up mine goes down under 20 psi (like 17 or so).... It didn't warmed up completly as I have water escaping from the
thermostat....
Readings through DD2 Lite using a sandwich plate under the oil filter.
Joao
Absolutely fine, mine runs......
Hot idle: ~10-12psi
Hot at revs (4-5k minimum): ~50spi
Thanks.
revving it the OP goes up to 60 - 70...
Thanks,
Joao
Yeh it will do until the oil is at 70-80c or more, once up to full running temp you'll probably see a bit lower than that.
