eNGINE IS NOW BACK IN, WITH EVERTHING UP AND RUNNING WITH NO LEAKS!! GETTING THE EXHAUST DONE MONDAY MORNING,
hOLESHOT SET THE CARBS A LITTLE ON THE RICH SIDE SO i COULD RUN IT UP TO TEMP TO CHECK EVERYTHING, THE ONLY PROBLEM WAS, I COULDNT RESIST IT, I
THOUGHT, RUNNING IT UP IN THE GARAGE IS OK BUT, SURLEY IT WOULD BE BETTER TO HAVE A VERY SHORT STEADY RUN UP THE ROAD ,
SO YOU GUESSEDIT, WITHIN 2
MINUTES IM STRAPPED IN, NO BONNET , NOSE CONE, OR EXHAUST, JACK SAID IT WOULD BE FINE TO RUN IT DOWN THE ROAD,
sTRAIGHT AWAY I COULD FEEL SOME SERIOUS GRUNT, THE TURBO WAS TRYING TO KICK IN STRAIGHT AWAY!!!
i GOT ROUND THE CORNER 1N 3RD AND GAVE IT ABOUT HALF THROTTLE, SH1T- MY HEAD HIT THE BACK OF THE SEAT, THE BOOST GAUGE ONLY READ 6 PSI, SO I TOOK IT
HOME,
IVE NOW GOT AN E BOOST TO FIT AT HOLESHOT, ITS BASICLY A 6 STAGE BOOST CONTROLL WITH A DIGI GAUGE AND PROGRAMABLE BUTTONS ON,
ILL TRY AND ATTACH SOME PICS.
[Edited on 16/7/06 by dilley]
say again? I couldn't quite hear you!
NOTHING WRONG WITH A BIT OF EXUBERANCE
Sounds like you're having fun to me
