So what should I be looking to change from standard? Springs I guess, anthing else?
Stock seems to be fine on the Busa with just uprated springs, a mate of mine is still running his stock clutch in a turbocharged busa putting out ~250bhp, although I suspect it will need uprating when he fully winds the boost up.
yip thats all i did as well,everything seems ok so far and it gets a little stick now and then
Was looking at this, but not sure if its necessary??
http://www.hayabusacentral.co.uk/shop/product.asp?idproduct=109&source=thumb
Further to the last question, just realised that the clutch is hydraulic. How is this operated? Obviously by a slave cylinder, but to connect a propshaft I have to remove this!
You need to remove some/most of the sprocket housing and space it out to suit. Assuming it's like the bird one.
Invest in a westfield megabusa one like i did - it goes against the 'locost' theme but is a lovely bit of kit!! Costs about 200ish quids.
Rich.
Errr no thanks!
Found a guy who makes billet slaves. £50!
