Emissions still struggling
esn163 - 22/9/06 at 04:13 PM
Hi
Spent afternoon trying to get emissions on 919 RRW blade within limits without success. Even with mixture screws fully in HCs still to high (think one carb may be leaking extra fuel in and causing HC to rise. Does this sound about right). On initial start up seemed fine but after 20-30 seconds HC rose to about 500PPM. Running std airbox without filter but no fish tank valves.
Any further thoughts.
Failing that how easy is it to change temporarily back to a 893 blade and what modifications are required. Also what does this mean for SVA requirements. Just another thought, having passed the speedo test with bike's speedo sensor would the speedo be tested again at the retest since we have already passed it with the 919 but the 893 doesnt have a sensor built in.
Thanks again
Ed & Simon
ecosse - 22/9/06 at 04:19 PM
I'll presume that you are not using one already, but why not bolt on a cat to get you through the emissions test?
Alex
esn163 - 22/9/06 at 04:26 PM
Hi
should have added using Chris Darby's twin cat system at the moment which has dropped them a lot but still too high
Ed
Paul (Notts) - 22/9/06 at 04:45 PM
I am still a year away from SVA but at this rate I may still be on the road before you Ed.
Paul
ecosse - 22/9/06 at 05:27 PM
Originally posted by esn163
Hi
Ed
Ouch
Have you checked the float heights?
If they are too high it can cause it to run over rich.
Not sure what carbs you are using but generally the mixture screw is for air mixture and screwing out allows more air in.
Alex
westf27 - 22/9/06 at 06:35 PM
When I had my SVA, my pinto engined car emissions passed.The CO was very weak causing High HC reading.Dont know if that helps.Apparently to due with incomplete burn.I hope this helps to diagnose your problem and apologise in advance if Im talking body bits
ChrisGamlin - 22/9/06 at 07:08 PM
919 / 893 engine is virtually a direct swap, the only difference really is the bore, its the same block and head etc, so uses the same mounts, exhaust etc, even the carbs.
The only thing on the 893 is the gearbox selection mechanism is reversed, so your gearchange direction will also reverse unless you make up new linkages etc, probably not something to worry about just for SVA. Also if you're using the bike speedo on the RRW that won't work on the 893 as there's no built-in speedo sender, although I believe a few have been able to get it working off a prop mounted magnet / pickup.
Apart from that I can't think of anything at all stopping a straight swap in / out
mac1 - 22/9/06 at 08:19 PM
The engine number perhaps,
ring me tomorrow Simon.
Mark
0114 2619633
[Edited on 22/9/06 by mac1]
ChrisGamlin - 22/9/06 at 08:32 PM
Hi Mark
I was assuming he puts it in prior to SVA, registers it with the 893 then changes the engine over afterwards with a corresponding engine number change on the V5, nowt wrong with that
watsonpj - 22/9/06 at 09:46 PM
The only other way is to have a active emissions system. i lent mine to Amalyos for his SVA and he got a good pass on emissions see here
LINK
this works by using a lamda in the exhaust and then has a control box that controls values that bleed additional air into the inlets (after carbs) as required. You set the car up a bit to rich and the electronics sorts the rest out.
However to fit its
1. make hole in exhaust and weld in nut for lambda
2. Fit electonics.
3. Replace each rubber carb inlet with modified versions.
4. Mount valves and contol box.
5. Wire it all up.
so basically its probably easier to put the other engine in, but I think this the only other option and you can pass with this as my fireblable did.
Pete
amalyos - 23/9/06 at 08:05 PM
The active system definately worked well, and wasn't difficult to fit on the R1.
Thanks again Pete, I'll call you tomorrow and drop the kit off if your in.
Steve.
