I'am about to buy a new Accusump from thinkauto for the ZX12 motor. Does anybody know what hoses and fittings I will need to buy as well. Also
what size accusump would you fit.
Cheers Carl
[Edited on 22/9/06 by carlgeldard]
I have just installed a 4 pint manual valve accusump.
After some advice we installed it into the oil gallery at the front of the engine.
this is a 3/8 fitting internal or 5/8 outer.
i got a hydrolic fitting 3/8 into 1/2" hose fitting oround £1 for this.
then depending if you are putting the valve directly onto the accusump or remote mounting will depend o the fittings you require.
we remote mounted it under the dash for ease of turning of and on.
remeber on all threads to get a tappered thread not straight as the do not all fit together otherwise,
any questions u2u me.
Sean
