noise level
desyboy - 28/9/06 at 08:34 PM
could anybody tell me what the db level is to get a bec through the sva cheers des
Hellfire - 28/9/06 at 09:24 PM
IIRC the SVA noise limit for any type of vehicle is 99db.
Phil
desyboy - 28/9/06 at 09:37 PM
thanks mate.
smart51 - 28/9/06 at 09:39 PM
The SVA guy said that mine measured 100 and so it just passed.
Hellfire - 28/9/06 at 09:41 PM
Or is it 100db......... hmmm.........
shortie - 28/9/06 at 10:02 PM
it's actually 101db, mine measured 104.9 so failed!! until I stuffed the customary wire wool in it!!
shortie - 28/9/06 at 10:09 PM
des,
I have a decibel meter you can borrow if you like, am seeing Donut on saturday so could leave it with him for you.
Rich.
[Edited on 28/9/06 by shortie]
Johnmor - 29/9/06 at 06:10 AM
Def 101db.
The test is done outside clear of walls and and surface that could cause rebound.
The meter is re-calibrated for each test
500mm from outlet and at 45 degrees.
I thought mine was loud, i also have a noise meter (99/100db) but when it was tested only recieved 91db.
The engine will be held at 75% of max POWER not revs.
Done on three occasions
Hope that helps
