Hi guys – could any of you tell me what clutch cable you have used as the one in mine is a bit on the short size and has been wearing and fraying at
the peddle end, so I am looking to fit a new one
I was at Brands on Saturday and saw a couple of Blades with very long cables fitted which looked like they would be a lot better than mine
A
[Edited on 16/10/06 by alanr]
Hi mate
Give mnr a buzz thats where i got mine from not cheap though but looks like it will last a while
i use a pedal bike brake cable. Once i managed to stop it slipping through it worked fine.
Have a look at www.venhill.co.uk - they do cable kits which I can highly recommend. They should be just over a tenner....
The one that Westfield supply for the Megablade etc is a Mk3 Cortina clutch cable, it has a ring / polo on the end for attaching it to the pedal with a clevis pin so may or may not be suitable for your pedal.
