R1 clutch wear
smart51 - 20/11/06 at 03:31 PM
Some people worry about bike clutch wear in a BEC. I've taken taken the clutch out of my 98 R1 after a year and 4000 miles of use, including 1
track day, ready to put in my new engine. The plates have worn by pricisely 0.0 mm acording to my vernier calipers. Thats with a Barnet plate and
springs and with EBC standard plates.
I must be doing something wrong
TimC - 20/11/06 at 03:37 PM
That's good news for me!
How's the poorly powerplant?
nitram38 - 20/11/06 at 04:04 PM
That's good news.........I have just bougt a barnet conversion!!!!!!!!
smart51 - 20/11/06 at 04:11 PM
In need of a good home. It runs quite well from 4000 - 12000 RPM. Pulling away from the lights, its touch and go. Compression is low and shoots up
with oil in the bores. The bores look fine and the honing marks are still clear. I've been told that piston skirt wear with high milage. This
leads to the piston siting at a slight angle on the compression stroke and presenting an oval profile to the bore, reducing compression. It's in
good condition otherwise. The gearbox is good, with 3 new gears and a selector fork. Lots of the gaskets are new. The head is good condition. all
the valves seat nicely and the valve clearances are all OK. It would be a nice engine for someone to rebuild, if that's their thing. If anyone
wants a spare for reasoanble money...
[Edited on 20-11-2006 by smart51]
alanr - 20/11/06 at 04:35 PM
how gentle have you been with it for those 4000 miles
smart51 - 20/11/06 at 07:12 PM
I'm usually fairly gentle when pulling away and have only done a full bore standing start a couple of times. Once rolling I accelerate as hard
and fast as the car / road / traffic permit, quite often to the red line.
I do clutchless upshifts if I'm accelerating but cluched upshifts if at a steady speed.
I guess it must be the full throttle-high revs standing starts that do all the damage.
