What clutch plates is everyone using in their zx12r cars?
I just fitted a barnett kit and its lasted about 50 miles...
Stock? EBC?
Which is best?
Stock? EBC?
Which is best?
Stock barnett springs... No problems so far...
Barnett plates but i havent got any experience of usage just yet as i still havent built the bloody thing!
I have a barnett pressure plate and springs with EBC plates on my R1. I had to put washers under the top hats to clamp the springs up a bit more to
prevent slip. I've had no problems since and very little clutch wear in 4000 miles and 1 track day.
Is your clutch slipping or are the plates worn?
Stock? EBC?
Which is best?
We have stock clutch plates with Barnett springs fitted. Upto now it's done a few drag days, trackdays and about 4,000 road miles. Still no signs of slippage. From other peoples experience of EBC clutches, I'd stay well clear. Most people usually swear by Barnett though, so can't understand why you've only got 50 miles out of yours.
Personally I'd go for stock everytime.![]()
Phil
Edit........ With the amount of knowledge you have Mark, I would have thought you knew the answer to your question.
[Edited on 22-11-06 by Hellfire]
you have done something wrong....
(or they)
50Miles... its impossible..
i gues in fact that if you return them to the UK they would like to inspect them.
garanties??
50Miles.. thats 1 hour at 50Miles an hour!
thats nothing.
Tks
[Edited on 23/11/06 by tks]
(or they)
garanties??
thats nothing.
Tks
You shouldn't really need a lock up clutch unless you're expecting to get more than about 200bhp out of your engine or you're into
serious drag racing. A stock OEM clutch will do the job without problems.
Still, it's your money.........
Phil
Just want to make sure, but i will start with oem plates and see what happens
