Hi,
Can anyone with Knowledge of the ZX9 B engine confirm the size of the resistor required to be fitted in the ECU Ign feed Please ?
I have installed a 100 ohm resistor, i have a spark and petrol but it back fires every now and again when being turned over and wont actually fire up
and run .
Any suggestions ?
100ohms is correct, are you sure the plug leads are on the right plugs?
Originally posted by Shogun969
Hi,
and run .
Any suggestions ?
Hi,
I believe plug leads are right 1 coil to plugs 1 & 4 , the other to 2 & 3, i have checked this against the wiring diagram but will recheck it
tommorow.
on my C engine, the leads were paired 1+2 and 3+4, but thats not saying much since i cant count and dont have the engine anymore anyway.
Hi Nick, you have U2U
Mark
