trt props
dilley - 15/1/07 at 06:59 PM
How much are they and how do they work??
can I have mine modified??
Andrew
PAUL FISHER - 15/1/07 at 08:46 PM
Spoke to Phil of the Hellfire team about this very subject yesterday,he said they had there old unit modified,at dunning and fairbank in leeds,its the rear section that contains the trt rubber, but Ive also read that it has been known for the rubber to split, and the question then is can they cope with the extra power of a turbo ,and they weigh a bit more than a standard shaft,so I am going to give them a ring,before I make my mind up.
Toady1 - 15/1/07 at 10:46 PM
if you do change to one then ill buy your std prop off you! the trt ones are around 250-300quid iirc.
PAUL FISHER - 15/1/07 at 11:24 PM
It sounds like they rework your old unit Toady1,Phil said it was around £125 for this service.
Gav - 15/1/07 at 11:30 PM
My TRT was from www.AutoPropuk.co.uk was 252 inc vat and delivery.
Toady1 - 17/1/07 at 10:44 PM
yeah, i didnt know this when i sold my cec prop! doah!
Coose - 18/1/07 at 09:09 AM
That's pretty much what I paid to have mine modded. They really are worth the money, being a lot smoother and this will translate to less shock-loading on the gears during changes. I couldn't recommend this enough!
