Guys,
Thanks for the replies this morning, very helpful.
Only a couple of things I am unclear of still.
Firstly Mark at MAC1 told me to turn the idle jets 2 1/2 to 3 turns out, does he mean the pilot jet on each carb or the air mixture screw on the
bottom of each carb or something else??
Also can anyone confirm whether I need to drill the slide lift holes to make them bigger?
thanks,
Rich.
[Edited on 25/2/07 by shortie]
turn out each mixture screw 2.5 turns to start with. if you have a tts dynojet kit dont drill the slides
Start with 2.5 setting (revs swetaly without one single miss.)
I enlraged the slider holes to 2.2mm using teh drill supplid with the kit.
My kit is a Djno Jet with individula K&N cone filters
If you ain't bunged the holes yet cocktail sticks do the job perfectly with the added bonus of been easily removed should you ever need too.
