has any one got any diagrams,parts list or any thing that will help me to turbo my fireblade engine
Quick list would be
Appropriate turbo
Exhaust manifold
Exhaust system
Pipework for oil/water feeds
Plenum (if injected) or other sealing around carbs
Maybe a more powerful fuel pump
Appropriate fittings like nuts/bolts and washers.
Short list; will get much longer as you go along
Simon
add to above^^^^
rising rate regulator,
new exhaust,
intercooler,
maybe bigger oil cooler and rad, also better ducting of air through nose cone,
boost gauge,
oil temp and oil pressure gauge,
loads of pipe work!
