Sprocket tooth amount?
CraigJ - 8/4/07 at 04:21 PM
What will give a good mix of acceleration and good cruising speed? i will be running a XJR1300 engine to a chain diff and could do with some examples of sprocket ratios?
Thanks.
[Edited on 8/4/07 by CraigJ]
froggy - 8/4/07 at 06:26 PM
use the stock ones to start with and work out the difference between the bike wheel and the car wheel which will be about 20% lower. my kitten runs on 10"wheels and standard tl1000 gearing which is 30% lower than the bike due to the diddy wheels and its at 11mph per 1000rpm which is a good compromise
buy a proper chain splitter of m+p too its about £60 but well worth it . ive cut my rear sprocket in half too so i can get it off qiuckly too
