Strong clutch cable
swalf3 - 27/4/07 at 09:44 PM
With my uprated clutch in the R1 the 1.5mm cable(throttle size) looks too weak.Where has anyone found a source of 2mm or 2.5mm cables and outer sheath for this application? Thanks Winston
Hellfire - 27/4/07 at 09:57 PM
Try Vehicle Wiring Products
Scroll down the page a bit to wire No 3 (2.159mm) or wire No 4 (2.642mm)
Phil
[Edited on 27-4-07 by Hellfire]
fesycresy - 27/4/07 at 09:59 PM
This may help:
Clicke Me
Lyn.
ChrisGamlin - 28/4/07 at 11:12 AM
Are you running a short straight clutch cable with the actuator arm turned round to pull towards the pedal, or it is in the stock position so you need a cable that has to go round a 270 degree bend to get into the correct position?
ChrisGamlin - 28/4/07 at 11:16 AM
Picture / thousand words etc....
Link to a bigger version of the same pic
This is how Rich Miles' did his on the R1 Striker, you can just see on the right the actuator turned around on its splines. Mines very similar with a cable outer bracket on my lower engine mount, but my clutch pedal is bottom pivot so the cable can be even straighter.
[Edited on 28/4/07 by ChrisGamlin]
bigrich - 28/4/07 at 01:41 PM
i'm using one of these cables from mac#1 also available from ebay on mac#1s shop
http://cgi.ebay.co.uk/Bike-Engine-Car-Clutch-Cable-BEC-MK-MNR-Locost-MAC-1_W0QQitemZ150113867020QQihZ005QQcategoryZ100921QQtcZphotoQQcmdZViewItem
zxrlocost - 28/4/07 at 04:19 PM
I used the original with no probs ?
swalf3 - 28/4/07 at 08:10 PM
Thank you everone for your replies.I will follow up the suggestions.Winston
