I have just fitted my propshaft, the front (to R1) section has a slide, then to a centre bearing (slightly angled) which I have mounted on the chassis
plate which was designed for the reverse box, then the rear section is (thicker) torque tube to my Sierra diff.
My question is, is there any sideways movement in the shaft when running, as there is only about 3-4 mm clearance each side of the rear shaft, where
is passes through the chassis tunnel hoops.
I would hope that a dynamically balanced shaft would not flex or move by this amount, surely if it did there would be severe vibration problems anyway
Hopefully somebody in the know will put my mind at rest ?
[Edited on 1/6/07 by millemg]
I'd give it more room than that personally, although it depends how "tight" your centre bearing is as I know mine for example would
allow far more movement than that (its designed that way).
Can you not put a spacer in between the mounting plate and the centre bearing to move it more central?
Originally posted by ChrisGamlin
I'd give it more room than that personally, although it depends how "tight" your centre bearing is as I know mine for example would allow far more movement than that (its designed that way).
youll find when its spinning it keeps itself pretty central
I can pull my prop all over the place by the bearing
but it obvioulsy doesnt do this when being driven
Question is, do I get the angle grinder on the inside of that front hoop inner l/h side and scoop a a radius out now while I can get at it ????
Looks close! Cornering forces might move it sideways?
Would you be better getting the tube hot and putting a dimple on the inside rather than cutting it?...just a thought!
Adrian
surely this is standard MNR stuff and Im sure Marc would answer this
afterall theres plenty off MNRs on the road
marc cant help if the prop is bigger than its meant to be! Is it an mnr supplied one?
sorry this is getting confusing dont Mnr Use standard ford props with modded ends
obviously I would never have known that
afaik they are all custom jobs.. ? I could be well wrong though but I dont think i've ever seen an MNR with a modded ford one.
that one does look a bit thicker than mine in the middle though.
my original rear part (i have a reverse box) was too close to the side bars, but it was at the thicker end where all the UJ stuff is. When measured
it was a little bit short so got it swapped for a slightly longer one so the end cleared the hoop.
of course thats no help to you as the length isnt an issue here.
