Just a few questions for you all:
1. Which filter and jet kit is needed
2. Sump modification/baffled/chopped
3. Clutch plates/springs etc
4. Where are the best places to get the above items.
Many thanks.
Hi.
Any foam filter and backplate will do, mines pipercross. TTS also do them Dynojet kit to sort the fuelling, and then ideally a R/R session to fine
tune.
Sump needs chopping and the drain plug moving to the side, shortened pick up strainer and a baffle plate. Chris gamlins uncle chops them nice and
cheaply. other option is a billet sump. but they cost a few hundred quid.
Standard clutch plates with heavy duty springs. TTS sell them amongst others.
Al.
Many thanks.
Cheers wadders.
My engine has the standard clutch plates, do i have to add any more plates?
Regarding the springs, can i get these springs from kwak, if so what are they off?
Hi
Try barnet springs with standard plates.
you can get away with mods to the standard airbox if you have a bonet bulge
Chopped airbox
Andy,
don't forget to install your manifold/headers!
Matt
