can you measure resistance between the pins on the top over sensor for me.
Thanks.
I'm getting a ZX10R (eventually) myself so hope you dont mind me asking - whats a top over sensor Dan???
Paul
I assume tip over sensor? ie it cuts the engine if the bike is dropped on its side.
yeah ive got the dealer manual and it says to measure voltage out of it but thats not too helpfull at the mo, if someone could measure the resistance would be much easier.
thats what i was going to do but simplified, if someone could measure the restistance i wouldnt have to mess about with pots (dont have any at the mo)
is the ground used or is it just the supply > resistor > output?
