Hi All
Thought I would introduce myself and say Hi as have been a member on here now for a few weeks. I am an engine management tuner and run a company
called 2Bartuning, i mainly specialise in the Japanese market but always find myself working on something weird and wonderful when contracting.
I own a Formula 27 Kit car with a Cbr1100xx fitted, before anyone asks yes an accusump is fitted.
At present the standard Super Blackbird engine produces around 150hp, well..so they say but have not had a chance to put it on my friends dyno yet.
This is fast enough at present without a passenger to 80 mph but after that the car starts to lose its grunt mainly due to the Diff Config being
favoured for quicker acceleration. The car at present will do a 120mph at 11k in 6th gear but im looking to change the Diff ratio to take the car up
to around 140mph to make sure on the straights at the track I don’t fall back.
In order to gain the extra grunt back I have decided to pop on a turbo. The unit I have favoured is a Td04 from an Impreza. This should enable full
boost around 4500rpm if my calculations are correct.
I have designed an air box setup that enables me not to make a massive hole in the bonnet like others have with the busa turbo’s kit cars but fitting
the turbo is going to require some cutting of the side trim.
Will be looking to run around 5-6psi of boost, which the stock engine should handle fine with its compression ratio.
I am unsure on the ecu setup that I am going to use at present as I will want to use 4D mapping due to the Individual throttle bodies. The way this
works is you map the car against a TPS signal to the lowest boost as possible and then use a map correction when the loads is increased above
atmosphere pressure. The reason for having to do it this way is due to the Map input signal not being fast enough or stable enough to get the correct
fueling in with ITB’s. The TPS signal is the fastest input which can be used and with ITB you need this especially with a light internal bike engine.
Once you have mapped it in 3d mode using TPS you then increase the pressure and use the 4D axis of Map to compensate for the Pressure tuning for the
VE .
Another option which I am considering is fitting a Emanage ulimate piggyback which is very advanced ecu compared to a power commander etc and this
would then make the mapping fairly similar as the 3d part of the map ie Tps will already be good from the stock ecu. We shall see how much time I get
available as will need a good day to get it up and running on a full standalone due to some not supporting the cbr1100cc trigger Config.
Will be fitting a rising FPR and inline walbro to help with the fueling but I will also be fitting some S2000 injectors as after using a spreadsheet I
made for injector hp calculations I don’t think the stock injectors will have enough for 6psi of boost and still be below 90% injector duty.
Here is the current custom airbox that is on the car which houses the stock filter
and here is the new sealed forced induction box which I have had made for me
Some time over the next few days I will be taking apart the td04 turbo to port the wastegate to make sure it will release enough exhaust energy at 11k
rpm. After this is complete i will move onto the the production of the manifold, alu intercooler piping, intercooler fitting, fueling and EMS
Stay tuned for more info…….
[Edited on 28/3/08 by Ryan.G]
nice
Ryan, where abouts in the world are you?
I *think* I spoke to you down the 'pod about 2years ago when I still had my Blackbird Fury (red). Which since found a new owner, and yet another
new owner (who is on here).
Of course I could be getting mixed up with another similar looking (and engined!) car.
Good luck with the turbo kit anyway.
I've got a TD04 sat at home for my 5PW R1
Won't be fitting that for a while though - prob not this year...
Originally posted by hobbsy
I *think* I spoke to you down the 'pod about 2years ago when I still had my Blackbird Fury (red). Which since found a new owner, and yet another new owner (who is on here).
nice car but the slope on your driveway looks a bit steep!
Hi there, nice looking car and nice work on the inlet. So its the Injection engine then. Will be nice to see it on the road as i have just turboed my CBR1000F engine........and broke it. lol
I too recognise the car from a trackday at Llandow a couple if years ago - nice one.
Hi,
great write up, I look forward to seeing how you get on! Did you buy you're car from Wolverhampton by chance? I considered one up there before
eventually buying my Blackbird engined Fury (mentioned in an earlier post)!
When you get around to updating your system I'd be interested in buying your old air box if it's for sale, my car currently has a horrid
foam filter which gets squashed under the bonnet.... less than ideal...
All the best, I look forward to the next installment.
Hi Yes its an Injection model from 1999
Sorry to hear about your car
What happened?
Also how did you find it with traction compared to N/A power and what diff setup do you have?
Ryan
Hi
I brought it from the staffordshire way.
Will let you know about the old air box as i might keep it just incase i dont like the power delivery with the turbo.
Ryan
Originally posted by itiejim
Hi,
great write up, I look forward to seeing how you get on! Did you buy you're car from Wolverhampton by chance? I considered one up there before eventually buying my Blackbird engined Fury (mentioned in an earlier post)!
When you get around to updating your system I'd be interested in buying your old air box if it's for sale, my car currently has a horrid foam filter which gets squashed under the bonnet.... less than ideal...
Very nice.
Did a double take on the exaust, which seems to be coming out of the "wrong" side of the car?
How is it routed?
Can you elaborate on th wastegate porting and why please?
And of course Hi and welcome
Col
[Edited on 28/3/08 by ReMan]
Originally posted by ReMan
Very nice.![]()
How is it routed?
And of course Hi and welcome![]()
Col
Cheers for the info.
I need to do some more research, but I really quite fancy turbo'ing the blade, as I don't want the bother of an engine swap in this car,
will leave that for the next one
Stop following me Ryan!
Spoke to you a few times on imoc (Nutter). I had the nuvelo blue MR2T
Welcome to kit car ownership!
Blimey, I'm an ex-IMOCer too - had a Rev 2 turbo.
Never handled as sweetly as my old Mk1 though....
Ahh but you couldn't beat the mk2T for power per pound lol!
here you go waste gate porting i did from standard
to modded
Hey Guys above
Update:
Got the manifold back from my fabricator
Getting closer just got a knackered diff to replace now
