can someone give me a list of parts need for exup
bypass box of tricks
thanks
which engine are you using? if it is for the R1, then you can find the circuit diagram on here is you do a search
If its unplugged does it make a difference apart from the error code?
Does this work for all models?
We are converting 2 cars to 2005 5VY R1's, i'll be using the bike clocks so will need to make something up but my mate is using different
clocks so if it don't make a diff he won't need one.
i have got info from a post on hear and they put up picture of there receiptand i have all but 1 part not sure what it is. receipt in picture and
maplins have no part number for it .
the number on the receipt is qq41 4503 i need to know what it is so i can order 1
thanks
Ok people ive found what you need here:
exup replacer
i have used this circuit on my 2006 5vy R1, and it seems to work fine. Only thing i will mention is on my 2006 5vy one of the wires is a different
colour to the wires on this diagram... all the others are the same, so i hooked up all the correct colour wires, then connected the last one up to the
remaining connection on the circuit
[Edited on 27/9/08 by Davey D]
