I am doing the last bits on my MK Indy-Fireblade before applying for SVA test. Paul Jepson is doing the paperwork and feels that I will most likely
need, which I haven't got, a "cat" for my 1995 RR-S Fireblade engine. 1. Is he right? 2. Is this something that is easily fixable? Bit
concerned as money is tight
Barry
August 95 is the cut off date.. so before that no cat, after defo a cat
Cheers for that, how do I find out the month of manufacture as I bought it on e-bay just as an engine?
I have the engine numbers listed from my Haynes manual. One sec and I'll post a picture of it!
Blade Engine numbers
Ta da!!
Hope that helps!
Edit - Not that helps with your exact month though! Sorry...
[Edited on 8/10/08 by McLannahan]
I think you are stuffed, unless the tester takes pity on you.
Perhaps you could get the info of the DVLA by them doing a search for the nuber on their super computer? no perhaps not!
