After a Zetec Shortened sump to go on a 1.8 Blacktop if anyone has one.
Can't help you with a sump, but just wanted to say they are really easy to shorten. The metal part can just be chopped so the deeper side is
level with the shallower side with, a couple of baffles if you want, and welded back up either with the original base or ideally some sheet steel.
If you want to add back in extra capacity that is a bit more complex but not too bad.
I did mine in 3 mm and even with my welding it doesn't leak.
Stu
[Edited on 17/7/18 by SJ]
I've got a mig and was going to go down that route, however I have read that if you are using the car on track days (which I am) its wise to get a pro one made. Not sure if there is any evidence to support this?
That's good to know.
Are you using a CVH sump? or are 1.8 sumps steel?
Standard blacktop 2 part sump, with alloy upper and steel lower.
All comes down to what you want to spend.
I’ve come across a guy that makes Blacktop sumps for F2 stock cars that look very suitable for a kitcar he comes very highly regarded for quality and
service. Neil Dunne , they are around 275 ready to fit.
I am going to revisit making my own but increase the capacity but I am tempted just buy one.
The best of the best is the raceline.
I choose the DIY route, cut and welded a block top 2 stage sump (cut and extended lower steel section). Then did some sums and worked out it was a half a litre under OE spec, I also wasnt convinced the basic baffles I added would do enough, so when an Acusump came up cheap I picked that up. Kits still not finished so cant comment beyond that, but IMO, an acusump covers multiple issues (cold start oil pressure, surge, and oil volume) which even a pro wet sump can only really give partial reassurance against 2 of those, so was a no brainer.
I’ve come across a guy that makes Blacktop sumps for F2 stock cars that look very suitable for a kitcar he comes very highly regarded for quality and service. Neil Dunne , they are around 275 ready to fit.
Yep in the past I’ve had a scholar engines sump and it’s the same sort of thing and quality. There getting harder and more expensive to find and I am not sure scholar still do them ? It’s a while since I looked.
+1 for Dunnell, top quality...
