carb balancing
bikecarbfred - 29/6/20 at 09:05 AM
want to balance the cbr600 1999 carbs: have purchased a 4 gauge carb balancer kit from ebay.
are these the 4 points where you attach the hoses to?
I always thought there were like coolant galleries. :/
I have blowed air through one checking to see if it travels to another opening but they dont. They seem individual gallery to each carb.
asn163 - 29/6/20 at 04:54 PM
Hi, when on the bike, the vacuum pipes fit into small ports built into the block/ inlet manifold. You remove the blanking plugs and screw in the adaptors for your gauge.
feckn7 - 1/7/20 at 05:54 AM
On my Blackbird there is one 'port' which goes to a vacuum tap on the fuel tank, the other 3 are blocked off with small screws - these are on the block just below where the carbs mount
