flanders
| posted on 6/3/18 at 02:22 PM |
Bec air box intake diameter
Im looking to design a cold air intake for my Reverie Hayabusa air box on my zx12r engine
im thinking of fitting a pipercross 100mm inline sock (see ink) to the airbox intake (100mm) then reducing down to 75mm for the cold air duct from
the nose cone. would the 75mm section be too restrictive?
filter - http://www.burtonpower.com/pipercross-air-filter-600-air-box-75-100mm-c6000.html
Reverie air box - https://www.reverie.ltd.uk/westfield-hayabusa-airbox-01.php
Im going to do something similar to this - http://mnrvortxrpehayabusa.blogspot.co.uk/2014/04/pipercross-px600-airbox-4.html
CosKev3
| posted on 7/3/18 at 04:28 PM |
I think 3 inch will be fine,pretty sure standard bike airbox entry points aren't that big
Andybarbet
| posted on 7/3/18 at 10:04 PM |
I'm using the PX600 airbox on my zetec with gsxr
600 throttle bodies. Also using the same pipercross filter in the mouth of the box.
I'm pretty sure I worked out that if I use a 3" duct to feed to the airbox, the surface area is almost identical to the surface area of
the 4 throttle bodies.
I managed to pick up a 3" naca duct at a very reasonable price to fit on the nosecone somewhere. 4" ones were trickier to find.
flanders
| posted on 8/3/18 at 08:17 AM |
Thanks lads, im trying to find out the size of the original intake of the zx12r motor bike so hopefully i can size it from that.
Id rather it was 3" as its easier and cheaper for the parts i need, and less bulky
I think im going to fit a cone filter in nose cone, then duct it back to the airbox rather than using the pipercross inline sock
[Edited on 8/3/18 by flanders]
flanders
| posted on 9/3/18 at 08:40 AM |
Luckily i bought a zx12r yesterday so i can measure the intake- if ive measured correctly the intake on the bike is equivalent to a 6.3 inch diameter
circle
the intake is a Trapezoid shape so i measured the circumference with string which gave me 500mm, this (i think) equates to a 159mm diameter circle
  intake
