Author: Subject: What battery for R1
the moa 2
posted on 16/1/06 at 11:19 PM Reply With Quote
What battery for R1
Trying to sort a battery for R1 and unsure what to get.
Obvious first choice was an R1 but at £60 odd quid i thought it was a bit expensive.
Looked in Haynes and it says battery is 12v 10ah so what other battery could i get ?
k33ts
posted on 16/1/06 at 11:23 PM Reply With Quote
try maplins rs etc they do drycell 12volters
the moa 2
posted on 17/1/06 at 12:12 AM Reply With Quote
I have found a few batteries but does anyone know if it has to be 12v 10ah or could it be 11ah or maybe 9ah ?
Kissy
posted on 17/1/06 at 07:59 AM Reply With Quote
I just went to the bike shop and asked to see the catalogue - picked one that was the right size for my fitment (not too tall on the scuttle) and exceeded the OE fit amperage (extra lighting/ancillaries). I think I ended up with a Goldwing battery IIRC. 30 quid. I'm not sure a drycell is up to the cranking amps, the cycling and long periods of inactivity - but would be happy to be corrected on this. BTW - I made up a shallow Polypropylene tray to sit the battery in (a small drop of acid will create havoc on an ally scuttle), and used 25mm woven webbing to clamp the battery down
Coose
posted on 17/1/06 at 08:32 AM Reply With Quote
I searched on t'internet and got a sealed R1 battery (can't remember the designation off hand) for £30 delivered. Seek and you shall find....
Spin 'er off Well...
progers
posted on 17/1/06 at 08:35 AM Reply With Quote
Go to mdsbattery.co.uk and pick up a Yausa or Varta equivalent of the R1 battery for arround £35 delivered. YTX-12 or something similar I seem to recall. These are good quality batteries.
- Paul
lsdweb
posted on 17/1/06 at 10:42 AM Reply With Quote
Maplin's have a deal on a booster battery pack. Take it apart and there should be a 17 Ah gel battery inside!
Link here
Wyn
the moa 2
posted on 18/1/06 at 12:09 AM Reply With Quote
Is this what you used lsdweb ?
the moa 2
posted on 18/1/06 at 12:19 AM Reply With Quote
the cheapest ive found is here:
http://www.motorcycle-road-and-race.co.uk/catalog/product_info.php?cPath=27_572&products_id=402328
not sue if correct spec but going by that code which is same as VARTA's it should be 12v 12ah
lsdweb
posted on 18/1/06 at 04:59 PM Reply With Quote
I haven't used that as I have a gel battery already (got mates working in an RAF establishment....). A friend has done this though and the battery was a pukka gel battery, although branded in Chinese.
I have one of those boost / starter things and, if I can, I may just take the top off for a look.
Regards
Wyn
RichieC
posted on 18/1/06 at 05:38 PM Reply With Quote
Sprint batteries arent bad, but if youre wanting piece of mind, definately go for a Yuasa or Varta, Ive never known one misbehave when cared for properly.
A mate put a new Yuasa on his ZXR last year after the Sprint was unrecoverable. The bike has sat in my garage, often in sub zero conditions and without fail it cranks and starts the bike when its been stood for months at a time.
Rgds
Richie
