Author: Subject: Prop Lubrication
Ferrino
posted on 19/1/06 at 02:44 PM Reply With Quote
Prop Lubrication
Do brand new props come pre-greased (guess so)?
Or should I ensure they're topped up as a precaution? If so, what type of grease is used?
Coose
posted on 19/1/06 at 03:42 PM Reply With Quote
It should do!
When you want to re-grease in the future, a good quality high melting point grease will do the trick. It should say on the tin/tube 'Suitable for wheel bearings, prop shafts etc.'.
Spin 'er off Well...
caber
posted on 19/1/06 at 07:00 PM Reply With Quote
Unless Ford type "sealed for life" GRRRR>
Caber
Dusty
posted on 19/1/06 at 10:47 PM Reply With Quote
My new prop has a sticker on it saying 'Please ensure this unit is fully lubricated with a Lithium based grease' so I will!
britishtrident
posted on 20/1/06 at 10:54 AM Reply With Quote
IMPORTANT don't over lubricate propshaft joints all you will do is stop the seals from keeping dirt out. Even greasing every 20K miles is probably too much.
jimgiblett
posted on 20/1/06 at 02:48 PM Reply With Quote
That interesting. I was taught to put enough grease so that it pushes the dirty grease out.
What ever you do make sure your UJs are properly lubricated. I have seen two UJs fail allowing the prop to flail in the tunnel. Fortunately without personal injury.
On inspection the spiders were dry as a bone and a very strong suspect of the cause of failure.
Rgds
Jim
Ferrino
posted on 20/1/06 at 03:36 PM Reply With Quote
Cheers guys.
It was a similar story which prompted me to pose the question
