the_fbi
| posted on 12/2/06 at 12:48 PM |
Thermostat for Blade?
How does one normally trigger the fan for the radiator?
I'm using a Polo rad and it has a boss for the normal fan switch, do I need to blank this as the Blade has a sender somewhere else or use it?
If I am using a sender in the radiator what's the best temp range to get for a 919/954 blade install?
92/87 or 85/80?
ta
Chris
Howlor
| posted on 12/2/06 at 01:33 PM |
No you should use this temperature switch position in the rad. The blade only has a thermostat to allow the water to pass through the rad.
the_fbi
| posted on 12/2/06 at 03:10 PM |
Thanks Steve
Any idea of ideal temp range?
92/87 or 85/80?
ta
Chris
esn163
| posted on 12/2/06 at 07:48 PM |
Hi, I seem to recall this came up recently however I cant find the thread. We are using a 98 919RRW blade in our indy using a westfield rad and plan
to use a thermo switch from
We
stfield parts store . I seem to think that the one for a blade is s the 97oC one from this
link but i'm not too sure. Is the Polo rad the same as the westfield rad?
Ed
[Edited on 12/2/06 by esn163]
Indy Build Photos
** Build pages **
Photo Bucket Pics
