Gav
| posted on 18/2/06 at 07:17 PM |
Whats this?
Just put my RRV blade engine on the bench to start cleaning it up and noticed their seems to be something missing.
if you turn your head 45 degrees to the right it might make more sense!, its right of the clutch cover and below the oil pump(?) is it some sort of
boss for a sensor or somthing?
ive looked through the heynes manual and i canrt find any refernce to it.
[Edited on 18/2/06 by Gav]
shortie
| posted on 18/2/06 at 07:46 PM |
Looks like the oil pressure sensor hole to me asfar as I can make out from the pic.
IIRR it's below the pulse genorator
Rich.
[Edited on 18/2/06 by shortie]
G.Man
| posted on 18/2/06 at 07:54 PM |
Looks like oil pressure sender to me as well..
Sure thats where I took an extended feed from on one of MNR's Fireblades..
Opinions are like backsides..
Everyone has one, nobody wants to hear it and only other peoples stink!
shortie
| posted on 18/2/06 at 07:56 PM |
Yep, I fixed my braided pipe to this and then to my sensor at the top of the cradle
Gav
Thanks, ill take a closer look at the heynes manual tomorrow now i know what im looking for.
Gav
| posted on 18/2/06 at 07:58 PM |
ok Thanks guys, ill have to remotley mount the oil pressure sender anyway as per the Digidash docs.
shortie
| posted on 18/2/06 at 07:59 PM |
Haynes manual doesn't really show it very well but there's basically a 1/8" NPTF thread in the bolt that the sensor screws into, if
you are not going to fit the standard one then you are best to use some braided hose and remote mount it as the vibration from the engine often means
the aftermarket oil pressure sensor can sheer off.
HTH,
Rich.
shortie
| posted on 18/2/06 at 08:23 PM |
If it helps here's a pic of where I mounted mine, I actually kept the original and fitted the Digidash one but the DD one has a built in low
pressure switch anyway.
[img][/img]
