Author: Subject: speedohealer
kev R1
posted on 28/3/06 at 08:01 PM Reply With Quote
speedohealer
anyone had anyone experience with 'speedohealer' looks a bit fiddly to use,any help would be greatly appreciated,cheers,kev
INDY BIRD
posted on 28/3/06 at 08:19 PM Reply With Quote
no piece of cake to use plug in and then just use a sat nav or a friend driving next to you to get your speedo reading verse the acurate reading.
Than go on there web site and type in the numbers on there calculator.
you will then get a list of no to type in and hey presto done.
must say mine works very well and is accurate.
also + point has a top speed indicator.
top product.
sean
kev R1
posted on 28/3/06 at 08:30 PM Reply With Quote
any tips on hoe to use? doesn't seem to be lighting up or anything, only a row of switches?
INDY BIRD
posted on 28/3/06 at 08:34 PM Reply With Quote
a small red light should come on and flash which is the button you press to change the % ratio that the speedo is out. this also does the top speed indicator.
it should just plug into the harness i think from the speed sensor from memory, double check connections i suppose but self explanitary to connect.
not sure otherwise sorry.
INDY BIRD
posted on 28/3/06 at 08:36 PM Reply With Quote
sorry aslo have you been on web site speedo healer.com may help with tips on problems.
