JoaoCaldeira
posted on 10/4/06 at 01:07 PM |
R1 sprocket bolt size
Hi all.
Forgot to measure when I left home...
Anyone knows what is the size of the bolt that hold the sprocket adapter for a 2002 / 03 R1?
Thanks,
Joao
fesycresy
| posted on 10/4/06 at 01:18 PM |
36mm rings a bell, not 100% though.
ChrisGamlin
| posted on 10/4/06 at 07:52 PM |
36mm is the size of socket you'll need I think, as to the actual bolt thread I don't know either
JoaoCaldeira
| posted on 11/4/06 at 07:26 AM |
Could it be 22mm?
Joao
tks
| posted on 11/4/06 at 11:11 AM |
mhhh
on my Honda VFR 800 its just
Bolt M10, with 1,25mm (pitch) thread
the longitud was small 35mm
sow socket 17 over here..
Tks
The above comments are always meant to be from the above persons perspective.
ChrisGamlin
| posted on 11/4/06 at 06:46 PM |
Thats not an R1 though TKS
Im not much use either Im afraid Joao, it sounds roughly right but I cant get at mine to measure it
locoboy
| posted on 11/4/06 at 07:13 PM |
Weird!
I have just been out and fitted my prop adaptor and discovered i need a nut for mine.
Is it a Yamaha dealer job or does anyone know the what thread nut i need for a 1998/99 R1 output shaft?
Locoboy
ChrisGamlin
| posted on 11/4/06 at 09:24 PM |
Yep it is a nut, the thread is what we're trying to work out, mis-worded above saying bolt
Coose
| posted on 12/4/06 at 01:16 PM |
Get the nut and tab washer from a Yamaha dealer - they cost peanuts!
But don't try to give them peanuts in exchange as they aren't UK currency. Unless they're covered in chocolate of course....
Spin 'er off Well...
speed8
| posted on 14/4/06 at 07:07 AM |
The nut and tab washer is a few pounds from the local Yamaha dealer. Best just to get it there.
