Author: Subject: More ZX12r starting probs!
athoirs
posted on 22/4/06 at 03:01 PM Reply With Quote
Ok.. Not getting any spark..
Engine turns over ok and fuel pump runs. FI light goes on for one sec then goes out after power up
All the interlocks have been removed ( I think!) and I have a 100ohm res on the gray wire.. (saw that someone put 150ohm in??)
anyone any other ideas...please
athoirs
posted on 22/4/06 at 04:08 PM Reply With Quote
tried a 150 ohm resistor.. still the same..
pin 20 (LG) on the ECU is at 0v and pin32 at 12v which is right. Could the ECU be "frozen" in a fault mode??
Smartripper
posted on 22/4/06 at 04:50 PM Reply With Quote
Hello,
Send you a email.
Daniel
athoirs
posted on 23/4/06 at 07:29 AM Reply With Quote
Got it going this morning..
My mistake (it usually is!) I had extended the wiring from the crank sensor- one of the wires I thought was black/yellow (ground) was in fact yellow/black (signal)...! give away was the fi light going off and on when cranking the engine!
big thanks For the e-mail it did help. All the info on it is correct
