fesycresy
| posted on 11/6/06 at 06:10 PM |
Oil Leak
I've just sprung an oil leak from the oil level sensor. It normally seals with an o ring but I've taken it out (cut it flat) for the sump
baffle.
I've cut an oval plate and used the back of the oil level plate to seal against the sump.
I've tried green hermatite but it obviously didn't work. Anyone got an suggestions, what about standard high temp hermatite, think it
would survive subjected to the constant hot oil ?
richard thomas
| posted on 11/6/06 at 07:33 PM |
I used to use blue Hylomar quite a lot, seemed resistant to most things. Unfortunately i ain't got any left or i'd let you have some.
Rich.
richard thomas
| posted on 11/6/06 at 07:51 PM |
HA! I lie.
Just been out to the garage and found half a tube - you're welcome to try it if you want. I managed to seal my fuel tank with this stuff so
it's pretty resilient !!
Rich.
fesycresy
| posted on 11/6/06 at 07:55 PM |
I'll check the spec. on their web site see if its up to it.
I'll give you a ring tomorrow.
Lyn.
caber
| posted on 11/6/06 at 09:18 PM |
alternative. . . Ignore leak and put cat litter on the floor under the car in the garage. . .works for Land Rovers...
Caber
Agriv8
| posted on 11/6/06 at 09:44 PM |
yup,
works for my v8, its not an oil leak its the chassis lubrication device
regards
agriv8
