Author: Subject: R1 BEC builders, please help!
kurt
posted on 26/7/06 at 08:25 PM Reply With Quote
Error codes!!!!!!!!
I know this has been discussed before but I've tried everything that has been suggested. My problem is the 8000rpm fuel sender not connected correctly error. I've tried various resistors, and a 1K variable set to different positions to con the diagnostics, and now resorted to a R1 fuel sender from a breakers but still I get the error. Any ideas?
I'm preparing the car for it's SVA retest which won't fail because of the error, but it's driving me mad and I want a working tacho. The clocks are 4XV 1998.
Cheers, Kurt
Bob C
posted on 26/7/06 at 09:52 PM Reply With Quote
Are you shorting the right wire for the fuel sender? (I know I was fooled by my data - turned out to be green/yellow)
Also the exup code is quite close at 7500rpm - you sure you have the right code? 1k worked for me (it's on the left of this little circuit http://freespace.virgin.net/bob.carter/images/exupcct.jpg)
Bob
zxrlocost
posted on 26/7/06 at 10:18 PM Reply With Quote
mine jumped up to about 9k for the fuel sender
so I just shorted the wires together its a green connector few inches from the rectifier unit
YES the fuel light is on all the time but so what
kurt
posted on 27/7/06 at 07:35 AM Reply With Quote
Thanks for the replies, I'll check it again today and report back.
Cheers, Kurt.
kurt
posted on 27/7/06 at 06:18 PM Reply With Quote
OK, I've checked the wiring and it's green and white direct to the clocks, and black to earth. Joining them together gives the same error. The actual reading is about 8500 rpm on the tacho, with the fuel sender, a 1K resisitor or a variable. Looks like the car is going back to SVA with a dancing tacho unless anyone else has any ideas?
ChrisGamlin
posted on 27/7/06 at 08:18 PM Reply With Quote
IIRC 470 ohm seemed to do the trick on my injected engine for the Exup and I think the fuel sender too, but probably different as the injected engine has the sender built into the pump
Coose
posted on 27/7/06 at 08:56 PM Reply With Quote
I used a 10k resistor on my 5JJ as that's all I had at the time, though it only causes the fuel light to flash on the later carb'd units....
[Edited on 27/7/06 by Coose]
Spin 'er off Well...
zxrlocost
posted on 28/7/06 at 04:57 PM Reply With Quote
touching the two wires together from the fuel sender plug on a 4xv should make the loom think theres no petrol and your petrol light come on it will stop the tacho error reading..
if it doesnt then its not your fuel sender mate
try the exup valve aswell
kurt
posted on 28/7/06 at 05:10 PM Reply With Quote
I've tried that so I'll have to check the others possible errors. I Just hope my clocks are ok, these are the second set I've had.
