Author: Subject: r1 inj fuel pump
adrian
posted on 20/8/06 at 09:44 PM Reply With Quote
r1 inj fuel pump
hi guys im on holiday in lanzarote at the mo!! ive been sitting on my sun lounger with a beer wondering what fuel pump i need for my r1 injection engine?
adrian
posted on 21/8/06 at 01:54 PM Reply With Quote
cant use r1 pump in my setup, dont want to cut a hole in my nice ally tank, do you know an external pump i can use? thanks
ChrisGamlin
posted on 21/8/06 at 04:39 PM Reply With Quote
we answered your question the first time you asked!!
adrian
posted on 25/8/06 at 08:16 PM Reply With Quote
hi chris,
thanks for your reply , i wrote it down before, when you replyed but i lost it!! didnt know how to trace an old thread, do you kno what filter to use cheers
ChrisGamlin
posted on 25/8/06 at 10:37 PM Reply With Quote
Can't remember to be honest, I think my inline filter on the pressure side may be for an Astra, but a lot depends on what size fuel line you're using (mine is 8mm)
iiyama
posted on 26/8/06 at 07:13 AM Reply With Quote
Do you use pre and post pump filters then??
ChrisGamlin
posted on 26/8/06 at 08:57 AM Reply With Quote
Yep, pre pump to stop any crap from the tank getting into the pump, and post pump just in case the pump itself starts to fail and sends bits of its internals down into the injectors etc. Obviously the pre-pump filter can be a simple clear plastic low pressure filter, but the post pump ones are usually ally/pressed steel case
chockymonster
posted on 26/8/06 at 11:06 AM Reply With Quote
For post pump I used a 2.0 focus fuel filter from halfords. 8mm in and out.
Pre pump is one of the little glass ones
ChrisGamlin
posted on 26/8/06 at 11:16 AM Reply With Quote
Ah actually Focus does ring a bell, mine's 8mm in/out too. It might be the pump itself thats installed in Astra (GTE's) amongst other things, making me think of that.
adrian
posted on 26/8/06 at 11:57 PM Reply With Quote
what pre filter is best?
adrian
posted on 27/8/06 at 12:56 AM Reply With Quote
chris, a bit of confusion with fuel pump part no.s
The pump you say is 0580 464 038 (rover v8)
Looked on rob collingdridges web page he brought one for a rover v8 0580 464 938? bit confused?
ChrisGamlin
posted on 27/8/06 at 11:02 AM Reply With Quote
I suspect one of us has typed the 9/0 wrong but if you google the number I posted, it does come up with a lot of Bosch fuel pump related links, if you google Rob's number it doesn't so I'd think his is probably wrong.
Chris
ChrisGamlin
posted on 27/8/06 at 11:04 AM Reply With Quote
Depends on what inlet/outlet size you need for your tank hoses really, but any carb fuel filter (ie one of the clear plastic ones) that's used on a similar powered engine or above should be fine.
adrian
posted on 27/8/06 at 06:53 PM Reply With Quote
yep you are right as usual!! rob has put a 9 instead of 0 (no results when i googled it) the no. you gave me came up with a pump that has a pressure of 3 bar (43.5 p.s.i) ,again thanks very much!
