desyboy
| posted on 1/10/06 at 12:30 PM |
cat/silencer
hi,
would anybody know where i can buy a lightweight silencer with a built in cat that would be quiet enough for sva that would work with an r1 engine?
Cheers des
matt.c
| posted on 1/10/06 at 12:40 PM |
very interesting question?
Would like to know that my self.
Thanks des.
bike_power
| posted on 1/10/06 at 12:53 PM |
Dave at Powerspeed Exhausts in Kent used to rent/lend them out to his customers. The one I had was basically a 5" silencer that Dave modified
with a cat and he welded whatever size inlet pipe you need. Not free but a cheap and dirty way to pass SVA.
StevieB
| posted on 1/10/06 at 01:09 PM |
There's a place in Lincolnshire called Tube Engineers (check Yell.com) - they do one for about £200 (I think it's that much).
If you go to www.dodgyroger.com, he used the same unit and seemed to pass SVA with no drama's in that area.
matt.c
| posted on 1/10/06 at 09:39 PM |
do you need a cat for the MOT?
ChrisGamlin
| posted on 1/10/06 at 09:47 PM |
Yep, my mate's Megabusa recently went for its MOT and he needed to fit one. I think previously you could often get away with it but with the new
computerised MOT system the computer automatically tells the tester what to test for, so its less likely to happen.
gingerprince
| posted on 2/10/06 at 12:18 PM |
...unless you have a Q plate, in which case it should override with visual smoke only as per the manual. Fingers crossed as I'm due
soon!
ChrisGamlin
| posted on 2/10/06 at 04:49 PM |
Ah yeh, good point
