dilley
| posted on 7/1/07 at 01:23 PM |
trumpets
Why are they different lengths?
Andrew.
indykid
| posted on 7/1/07 at 01:26 PM |
for playing different music?
on a more serious note, by using different length trumpets alters where peak power is in the rev range or something to that effect.
tom
DIY Si
| posted on 7/1/07 at 01:31 PM |
They are different length for different inlet tract lengths. This alters the frequency at which they resonate, and boost torque. Often useful for
filling in holes in the torque curve or boosting peak torque. Oh, they also smooth the airflow into the carbs/bodies and aid overall power because of
this.
Sun Tzu, The Art of War
dilley
| posted on 7/1/07 at 01:32 PM |
I have 2 longer yhan the other 2, it doesnt make sense to me, I could understand if they were changed as a set.
G.Man
| posted on 7/1/07 at 01:33 PM |
Longer gives more bottom end/mid range torque..
Shorter gives more top end.. in a nutshell..
Its a bit more complex than that, profile airbox design, position of filter and/or intake relative to trumpets..
I believe some blown engines use different length trumpets within a plenum to balance the airflow... but that is beyond my level of knowledge...
Opinions are like backsides..
Everyone has one, nobody wants to hear it and only other peoples stink!
G.Man
| posted on 7/1/07 at 01:34 PM |
the 2 inner ones can be different to the 2 outer ones on a few bikes I have seen..
What bike is it? as some bikes also changed trumpet lengths and bores on different model years and you may have received a mix n match set..
LOL
dilley
| posted on 7/1/07 at 01:40 PM |
Its a blackbird, its all running fine, I am just curious.
RazMan
| posted on 7/1/07 at 02:10 PM |
The Duratec V6 uses two lengths of inlet tracts which are opened by a butterfly mechanism above 4000 rpm to boost the top end torque and closed to
give more bottom end.
Raz
ChrisGamlin
| posted on 7/1/07 at 03:05 PM |
I suspect they use different length tracts on the inner ones so that they can spread out the torque characteristics by having two cylinders producing
more torque at lower rpm, and the other two slightly higher, rather than one slightly larger peak but only at a single rpm.
Also the two inner cylinders generally run hotter than the outer ones due to having another hot cylinder on both sides, to the extent that they run
different fuel mixture settings on the inner two (certainly on the injected R1) so maybe that also has a bearing on it.
G.Man
| posted on 7/1/07 at 03:19 PM |
chris is spot on, the R1 has to have richer jets on the middle 2 cylinders to balance the heat...
I think the longer trumpets MIGHT be for the 2 inner cylinders, maybe due to the shape of the airbox..
You will need to look at the owners manual to make sure... Haynes do one for the blackbird which should cover it
DIY Si
| posted on 7/1/07 at 05:27 PM |
Yup, the longer two live in the middle, as Chris said, to spread the torque out a little. It helps level out spikes in the power curves.
roadrunner
| posted on 7/1/07 at 08:09 PM |
So why is it better to fit an air box on bike carb's.
DIY Si
| posted on 7/1/07 at 08:39 PM |
You can then tune the inlet even more to a particular rev range. It's an extension if the trumpet idea basically. It gives a bigger volume of
air that is matched to a rev range to give a little positive pressure to the carbs. Again, used to fill holes in the torque curve.
ChrisGamlin
| posted on 7/1/07 at 09:31 PM |
Yep, if (and its a big IF) you can get the airbox the right size and shape, you can start getting the effect known as pulse tuning where the resonance
(ie timing of the pulses) of the air coming into the airbox coincide with the inlet valves opening on the engine, so you get a mini supercharging
effect. Its only small, maybe worth a few horsepower on a bike engine, but if you get it wrong it can have the opposite effect and almost cause a
negative pressure so less air enters the cylinders than it would without the airbox.
Running without an airbox has its pitfalls too though, because you're sucking in hot air from the engine bay, and also sucking in quite
turbulent air especially if the air filter sticks out the bonnet.
smart51
| posted on 7/1/07 at 10:35 PM |
Pulse tuning of an airbox (and all airboxes do this) adds a small positive pressure at the tuned RPM and at half that speed and a quarter of that
speed. In between these you get negative pressure which worsens torque. the effect is slight but can be useful to flatten a spike or fill in a dip
in torque.
My R1 engines both have fairly low acceleration up to 5000 RPM when suddely they take off. By tuning may airbox to 4500 RPM, the power now rolls on
gradually from 4200 to 5000 RPM. It also sounds happier at full throttle in the range that it did before.
If trumpet length does the same thing then perhaps you could use it to cancel the dips caused by the airbox tuning, just leaving you with the primary
airbox resonance.
Phil.J
| posted on 8/1/07 at 04:36 PM |
Have a look on the Jenvey website. They have a very handy theory page explaining this and giving advice on the correct trumpet length/ throttle body
diameter for each capacity engine.
Phil
ChrisGamlin
| posted on 8/1/07 at 07:43 PM |
speed.
Sorry yep, I forgot to mention that its at a specific rpm so I guess all airboxes will do it at some revs, its getting it to pulse at the right revs
thats the tricky bit.
