Jon Ison
| posted on 4/3/07 at 03:11 PM |
Honda / Blade rectifier plug ?
I would like too change the push in plug, its old and in the past has been a tad hot so also a little burnt.
Question, the three yellow wires, is it important they stay in the same position in the plug ?
Would it cause a problem if I was too shorten the wires in an effort too tidy up the engine bay wiring a little ?
Anyone konw a source for these plugs ?
mark chandler
| posted on 4/3/07 at 05:56 PM |
When I changed my rectifier to a larger one the plugs did not fit, I bunged them on the new rectifier in the order that I picked them up in and it
works fine.
All you have is a bridge rectifier inside the regulator so its would make absolutely no difference in what order they land as far as pulling out the
volts, not sure how the regulator bit works but this stage is later on so irrelevent.
Regards Mark
worX
| posted on 4/3/07 at 06:37 PM |
I asked the same question to Mark MAC#1 and he told me that it doesn't matters which way round the go - I will add however that it is fine to
cut the wires shorter but they are quite heavy wires so if you have to elongate them at any point then you must use appropriate cable for it.
I am sure if you gave this guy a call http://www.polevolt.co.uk (Neil Talbot) he would be able to sort you out with corresponding plugs, he's a
top bloke and local to me but does do mail order (he's also in the links section of this site).
cheers,
Steve.
Jon Ison
| posted on 4/3/07 at 08:06 PM |
Thanks,
Thinking about it a bit more is it ok too make them longer ? If I did so I could mount it in a position that would get more and cooler airflow around
it ?
Currently its up on the scuttle behind the engine, it will be warm up there with no airflow too speak of.
shortie
| posted on 4/3/07 at 09:27 PM |
Should be fine to make longer as long as you use the same sized cable, if you wantr some I think I have some 3mm spare, I think in yellow aswell, how
much do you need jon.
As for the plug is the the one that specifically fits the rectifier?
Rich.
[Edited on 4/3/07 by shortie]
Jon Ison
| posted on 5/3/07 at 05:19 PM |
Me again,
Tried polevolt, your right, spot on bloke but unfortunately couldn't help, he did say he would love too get hold of the motorcycle
plugs/connectors as he his asked quite regularly for them.
I asked what he thought too me doing away with the plug and using normal connectors, he didnt see it as a problem, does anyone see a problem with it
Shortie, yup the one that pushes into the rectifier, 5 cables but what looks like a plug for 6.
Thanks for the cable offers guys, I'm ok on that score.
mad-butcher
| posted on 12/3/07 at 07:28 PM |
been away on holiday hope this helps
http://www.hondaspares.com/newparts/details/default.asp?prodID=103003&mydep=260
Jon Ison
| posted on 12/3/07 at 08:19 PM |
If you wasn't an hairy bloke I would kiss you..........
mooooowhaaaaaaaaaa
Yes it helped.
Jon Ison
| posted on 12/3/07 at 08:20 PM |
Bugger, there out of stock........
mad-butcher
| posted on 12/3/07 at 09:07 PM |
http://www.davidsilverspares.co.uk/
