Author: Subject: R1 quicky, sounds like a V8!
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 13/3/07 at 07:31 PM Reply With Quote
Slowly getting the car into shape! Out today. When you down shift when slowing down (or whatever), the exhaust splutters and pops. It sounds superb, like an old V8, but if due to rich running or some other reason, is this likely to cause any damage to the engine?
Ed
ChrisGamlin
posted on 13/3/07 at 08:12 PM Reply With Quote
It may well be a small air leak in the exhaust manifold somewhere, it wont do any damage to the engine but it can blow the packing out of your silencer in short time if it does it a lot. Probably worth it for the noise though
andyharding
posted on 13/3/07 at 09:13 PM Reply With Quote
It never ceased to amaze me the b0ll0cks people spout out about this subject and lengths they go to to try and stop it.
In short it is a good thing if it back fires / pops when on the overrun.
If you want a full explaination why read up on the subject on google etc.
[Edited on 13/3/07 by andyharding]
Are you a Mac user or a retard?
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 14/3/07 at 09:35 AM Reply With Quote
Thanks Gents
Won't lose any sleep over it for a while then!
Ed
G.Man
posted on 14/3/07 at 10:29 AM Reply With Quote
No it shouldn't cause any damage.. (see below)
With a carbd'd engine its just the "idle" mixture being burned in the exhaust.. or the unburned proportion of it...
With a fuel injection engine, it depends on how the engine is setup.. A good fuel injection sytem will pretty much shut off fuel to the injectors when you lift off the throttle, so they shouldnt pop/backfire excessively... if it does, you may want to check your fuel pressure regulator is properly connected to the vacuum line (this is what opens to return fuel to the tank when you lift off the throttle)..
Other things to check are the throttle position sensor, and finally the exhaust headers..
I don't agree backfires are a good thing, as I have seen mufflers blown apart, but the certainly arent as bad as you would think, as in most cases its just unburned fuel...
Opinions are like backsides..
Everyone has one, nobody wants to hear it and only other peoples stink!
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 14/3/07 at 05:38 PM Reply With Quote
It's on carbs and so far it is exactly as we picked it up regarding tune. Goes well, sounds superb but as long as its OK for the mo, I'll leave it until we get a checkup done.
Regards
Ed
