TimC
| posted on 21/5/07 at 12:09 PM |
5JJ R1 Sump - bolt missing?
Now that the engine is in the chassis, I can get under it. I seem to have a bolt missing. You can see the hole at the bottom of this pic...
Pic Here
I assume that there should be something in there??
Ta
ChrisGamlin
| posted on 21/5/07 at 12:17 PM |
Nope, I think its the water pump breather hole but looks slightly different to my 5PW so not sure.
On mine anyway, there's a little copper pipe that has an O ring on each end that exits out through the sump that allows the (internally mounted)
water pump to breathe. Bit of an odd design venting out the bottom of a sump but as long as the O rings are OK, there's no leaks.
bodger
| posted on 21/5/07 at 12:49 PM |
It's definitely the water pump drain hole. All becomes clear when you drop the sump. BTW I did have a bolt missing when I refitted my sump.
Looked high & low for it 'cos I definitely had it. Eventually dropped the sump again & there it was sat in the bottom of it! doh!
