roadrunner
| posted on 27/6/07 at 06:07 PM |
Gear seletor
In the last couple of runs , i've either missed a gear, which i thought you could'nt do with a bike engine , and then last night, a bit of
a crunch when selecting third.
what i want to know is, is it the selector, and is it expensive and difficult to change , in a zx9.
| posted on 27/6/07 at 06:27 PM |
Sounds like the 'throw' on your gear selector isn't pushing the gear selector far enough.
I've had that on my ZX9 if your a bit lazy on the gear stick. You need a good positive selection to get then in first time.
roadrunner
| posted on 27/6/07 at 06:51 PM |
It does seem to happen when i'm pushing on a bit, i will have a look before i take the engine to bits.
Cheers coozer
jacko
| posted on 27/6/07 at 06:55 PM |
Odear another bike box bet you wish you still had the type 9 know
PINTO POWER PINTO POWER
roadrunner
| posted on 27/6/07 at 06:57 PM |
it would still out run a pinto.
jacko
| posted on 27/6/07 at 07:04 PM |
NOT FOR LONG
| posted on 27/6/07 at 07:10 PM |
Obviuosly a bike engine is better than a potatoe power pinto... IMHO!
speedyxjs
| posted on 27/6/07 at 07:27 PM |
well how about JAG POWER
Hellfire
| posted on 27/6/07 at 07:57 PM |
Yep. It would outrun one of those too. Waaay too heavy
Phil
jacko
| posted on 27/6/07 at 08:06 PM |
Not without a gear box
roadrunner
| posted on 27/6/07 at 08:20 PM |
The box is fine, it's just me being in too much of a rush.HE HE.
jacko
| posted on 27/6/07 at 08:30 PM |
Thank God for that summer is short enough without it been
of the road for gear box problems .
We just need the weather to get better .
Cu soon
Graham
Wadders
| posted on 27/6/07 at 08:39 PM |
Check the gear linkage, ZX9's need a good positive shift, any slop in the linkage will potentially give you problems. If its a 'C'
model
it's par for the course, but normally happens on downshifts.
Al.
roadrunner
| posted on 27/6/07 at 09:44 PM |
Cheers wadders, mine only happened on upshifts,but it could be the long linkage flexing, if i'm driving steady, i have no problems at all.
| posted on 27/6/07 at 09:55 PM |
Def check the linkage....
Also, is it any particular gear? When I shift from 1st to 2nd I have to give it a fairly meaty shift- any other gear it's super light....
awinter
| posted on 28/6/07 at 08:17 AM |
I get the same problem on the upshifts if I rush a change. End up in neutral its me not the box. Box is fine and I use the clutch for down shifts.
Allan
Edit, I bought my car from Coozer, so he could be talking about the same engine.
'allo steve
[Edited on 28/6/07 by awinter]
roadrunner
| posted on 28/6/07 at 06:36 PM |
I use the clutch all the time, can you get away with not using it.
Toady1
| posted on 29/6/07 at 08:29 AM |
apparently so mate, on the up shifts and once in 2nd anyway! My mate does it on his bike all the time. Not too sure how well the box will like it
tho??? I think ill be a bit sympathetic with mine and use the clutch when driving slowly, and clutchless changes when going for it.
Hows the conversion going anyway? Im so close to finnishing mine now! cant wait!
Hellfire
| posted on 29/6/07 at 11:19 AM |
No need to use the clutch at all on upshifts. The higher the revs, the sweeter the gear drops in, although you may wish to use the clutch in the first
few gears if going slowly
It's a fine art doing clutchless downshifts though and personally, I would avoid it in a BEC application.
Phil
gingerprince
| posted on 29/6/07 at 11:38 AM |
tho???
If you do it right the bike actually prefers it, due to the dog arrangement of the gearbox. if you use the clutch then you are slowing down the
output shaft and creating a speed differential that "clunks" when you release the clutch. this technique is "taken" up in
traditional synchromesh gearboxes but a bike gearbox is a completely different design. there was a good article somewhere on i think
howstuffworks.com that explains it in detail.
speed8
| posted on 29/6/07 at 12:42 PM |
Clutchless upshifts are no problem on a bike engine although I prefer to use clutch between 1st and 2nd due to neutral being in there.
Downshifts can be down too but there is more wear in the box and more chance of mashing things up so I personally use the clutch unless I'm at
low revs on the downshift (apart from the risk of locking the rear on a bike)
