dave r
| posted on 26/7/07 at 05:14 PM |
bike carb spacing
lo all
not for a bec, but are all bike carbs a similar spacing as standard ?
i have aquired a set of carbs aledgedly off a 600 bandit
they are spaced 75mm centers
are others the same, as they appear to be bolted together, with no easy way of changing for diffent bikes ?
hope that ramble makes sense
dave
Wadders
| posted on 26/7/07 at 05:19 PM |
HI Dave
Similar, but not all the same.
Al.
]Originally posted by dave r
lo all
dave
| posted on 26/7/07 at 06:58 PM |
Negative, most a slightly if not a lot different.
I have two sets of carbs from a ZZR1100 and a ZX9R that look identical.
There is 3mm extra width each side on the 900 carbs
dave r
| posted on 26/7/07 at 08:24 PM |
they are keihin carbs from what i have been told a bandit ???
all 4 carbs look identical, so was hoping all bike carbs were sort of the same....
time will tell i guess
dave
matt_gsxr
| posted on 27/7/07 at 04:31 PM |
Some suzukis (mostly old ones) have their cams driven off a central chain drive. This results in an extra gap between the central two cylinders.
The individual carbs are identical (i.e. each of the 4 are interchangeable).
Matt
