iiyama
| posted on 30/8/07 at 06:57 PM |
Busa wiring diagram
Anyone got a copy of a wiring diagram for a 2003/4 Busa? The one I have only goes to 2001 and I have a few discrepancies between the loom and the
diagram!
Ian
If its broke, fix it. If it aint broke, take it apart and find out how it works!
yorkshire-engines
| posted on 30/8/07 at 07:45 PM |
Hi i havent a diagram but i know whats what let me know what you wanna know
cheers malc
iiyama
| posted on 30/8/07 at 08:24 PM |
Probably making my life difficult Malc!
Need to know what the relay is thats built into the fuse box. It has seven terminals! Ive cut all thi out to mount a relay/fuse box on the bulkhead. I
think its a flasher relay, but seems to have a hazard capability? Also there is a wire from the side stand switch going into it. Why? There is a cable
from the gear position switch going into it between what appears to be 2 diodes. Again, why?
The gear position switch is there to a/ stop the engine being started while in gear and b/ to indicate neutral on the dash?
Also I have a yellow/blue wire coming from the fuse box. On the diagram I have there is no yellow/blue.
And one last question for now! The speed sensor. How do I get this to work? Something to do with magnets on the propshaft I believe? Need some
pointers though. ie how many and how close does the sensor have to be to them?
Ian
iiyama
| posted on 1/9/07 at 02:57 PM |
sorted!!
