Author: Subject: 'Blade Choke cable
andrew.carwithen
posted on 26/9/07 at 11:35 AM Reply With Quote
'Blade Choke cable
Having done a search for an appropriate choke cable, the general concensus of opinion is to use a 'Mini' type cable and a suitable nipple to attach to carb end.
Anyone know how long these cables are? (I reckon I'll need one about 5 - 6ft in length) and where to source said nipple?
Andy.
asn163
posted on 26/9/07 at 11:43 AM Reply With Quote
Hi,
I can't. comment on what cable it would be, but are you sure you need one?
We have never had one fitted to our 919 Blade and have not had any starting problems.
Simon
worX
posted on 26/9/07 at 11:45 AM Reply With Quote
I started out with one on mine Andy, but removed it because I never needed to use it - you can have mine if you like, but it really isn't worth it...
andrew.carwithen
posted on 26/9/07 at 12:09 PM Reply With Quote
Hmmmm.....thing is, from cold, it just won't start without choke - no matter how much/little throttle I give it. (maybe simply because engine isn't fired up regularly?)
Soon as I manually operate choke mechanism on carbs it fires into life at first press of button. As yet I haven't fitted a dynojet kit or checked carb balance/ idle mixture etc. so whether any of this has any bearing on start -up?
How long is your choke cable, Steve and is is it the Mini locking type?
I'll swap it for the handbrake lever I promised I'll send you! (note to self: Must get down the Post Office!)
Andy.
worX
posted on 26/9/07 at 12:49 PM Reply With Quote
Mine wasn't long enough to reach the dashboard I'm afraid Andy, so you might be best off buying a longer one anyway!
But, it did reach the back of the scuttle, so when I used it (only to check it worked) it was ok to just lean forward and reach under the dash a few inches.
Like I say, it's yours if you want it for free (well swap !)
What is your car ticking over at when cold?
PhilCross66
posted on 26/9/07 at 12:50 PM Reply With Quote
I've used the mini choke cable method on mine.
I attached a normal nipple to the end of mine by leaving an old nipple on a short bit of cable and using a bit of electrical connecting block to join it on the end.
Mine will start without it but I have got a full airbox on, it wont start if I leave the airbox lid off.
mike smith1
posted on 26/9/07 at 01:12 PM Reply With Quote
Used the bonnet release cable of the donor and activated it with the release handle under the column, works a treat!
Mike
Hellfire
posted on 26/9/07 at 01:22 PM Reply With Quote
On the earlier blade engines, carbed engines would not start without choke... FI is different, depends upon your engine choice.
We used the Sierra bonnet release cable on our 'blade install as she too would not start when cold without some extra juice!
On the FI kwaka - no problems.
Just as a thought, the new NGK Iridium Plugs help with cold starting as the nose temperature is hotter almost instantaneously, this helps to reduce the cold carbon deposits which accumulate on the core in cold temperatures.
andrew.carwithen
posted on 26/9/07 at 01:25 PM Reply With Quote
Mike
Trouble is, I'm missing the release lever (bleddy good solution, though) so I'll have to use a universal choke cable of one form or another.
Steve (Worx) I'll get a longer cable (if I can) so that I can dash mount it. Don't worry, I'll still pop the handbrake lever in the post next time I'm out.
Andy.
worX
posted on 26/9/07 at 01:41 PM Reply With Quote
No worries Andy - if you don't get one let me know and I'll stick this one in the post for you!
ps mine is:
Carb'd RRT Blade engine on TTS filter & standard plugs - starts fine from cold...
welderman
posted on 26/9/07 at 02:08 PM Reply With Quote
Same as Hellfire choke cable and bonnet catch
[Edited on 26/9/07 by welderman]
Thank's, Joe
I don't stalk people
Jubal
posted on 26/9/07 at 02:45 PM Reply With Quote
Mike
That's how mine is done. Nice and neat. It will not start from cold without it but settles right down after 30 secs.
ASH3
posted on 26/9/07 at 08:33 PM Reply With Quote
My 91 Blade if left for a week or more
requires the choke to start i dont bother
with the cable cause never sure if its fully
off so i lift bonnet and work it manually. So
no need to mess about fitting a choke cable in my opinion.
ripsnort
posted on 30/9/07 at 02:49 PM Reply With Quote
I have used a universal cable much like the mini version it is about two metres in leghtn and have it hidden under the dash on the steering column, make sure you get a lockable one.
Rik
