kastrato
| posted on 2/10/07 at 05:22 PM |
fireblade air filter
I was wondering what air filter you people use for your '95 fireblade?
i use the oem one at the moment but I am fancy these sausage filter ones.
If I get a sausage filter do I need re-mapping?
Where can I source a decent filter in a good price?
MK INDY fireblade
Bladerunner
| posted on 2/10/07 at 07:43 PM |
Air Filters
I used Pipercross Socks, one for each trumpet, cut down to fit under the bonnet.
What you will have to do in enlarge the jets you use compared to the normal air box.
Good luck.
kastrato
| posted on 2/10/07 at 09:05 PM |
do you have any pics with your filter/s
any pics of the jets you using?
where I can supply all these things?
thanks for the reply!
MK INDY fireblade
trifield
| posted on 4/10/07 at 07:46 PM |
Hi, put some pictures in my photo archive.
Have dyno jet kit fitted to suit the filter.
Neil.
kastrato
| posted on 5/10/07 at 02:18 AM |
Now it is time to make full of my self...
What is the dyno jet kit?
By the way your MK looks the nuts mate!!!
MK INDY fireblade
kastrato
| posted on 5/10/07 at 11:29 AM |
ok ok I figured out my self!
So for a decent air filter system you need about 200 pounds.
Does it makes any difference on performace?
MK INDY fireblade
Hellfire
| posted on 5/10/07 at 04:19 PM |
I doubt you'd get a noticeable improvement in performance by switching to a foam filter. Your money would be better spent on getting the
suspension geometry set up IMO.
Phil
Jon Ison
| posted on 5/10/07 at 05:17 PM |
Mine made/makes more power with an air box over foam or no filters.
