Ben Smith
| posted on 23/2/06 at 12:27 AM |
R1 clutch movement
How much movement should there be in the clutch arm? There seems to be just under quarter of a turn to take up the slack (arm now pointing directly at
side of clutch cover). Then the arm goes tight. I have read that it is difficult to just move the lever by hand but it is now connected to the pedal
and still doesn't really want to move. I was expecting this to be very light to operate. Are we right in assuming that the 1st bit of movement
is just the slack?
Ben.
Ps. Engine sounds fantastic!!
smart51
| posted on 23/2/06 at 08:00 AM |
tighten up an adjustable spanner round the clutch arm. this will give you enough leverage to operate the clutch by hand.
Coose
| posted on 23/2/06 at 11:24 AM |
Once the slack is taken up, you should be looking at about 12mm of linear movement on the cable.
[Edited on 23/2/06 by Coose]
Spin 'er off Well...
