amalyos
| posted on 26/3/06 at 06:58 PM |
R1 Clutch & Gasket
Before I fit the engine, I thought I'd take the opportunity to change the clutch.
Is a std clutch sufficient for a BEC, or should I fit an uprated one?
Where's best to get a clutch and gaskets? Direct from Yamaha or is there anywhere decent on line?
Cheers Steve.
fesycresy
| posted on 26/3/06 at 07:06 PM |
Double up on the spring.
Cheap enough from your Yamaha dealer.
ChrisGamlin
| posted on 26/3/06 at 07:10 PM |
Doubling up on the diaphragm spring is the cheap way of doing it and seems to work. Alternatively there is the Barnett spring conversion at ~£100
which converts it to conventional 5 coil springs. I think this should give better pedal feel and allows you to add stronger springs if required, but
obviously costs considerably more than a second diaphragm spring!
As to plates etc, the standard Yamaha ones seem as good as any, not heard any horror stories or anyone saying Brand X is significantly better.
speed8
| posted on 27/3/06 at 10:46 AM |
I've went the Barnett route. I wanted a bit of a heavier feel after driving the cerb for so long. I've kept the old diaphram just in case
of emergency!!!
ChrisGamlin
| posted on 27/3/06 at 06:58 PM |
Yep me too, ISTR reading comments that the double diaphragm spring setup can sometimes be unprogressive across its range so can lead to a slightly
snappy clutch take up, but I have no first hand experience of that.
ChrisGamlin
| posted on 27/3/06 at 06:59 PM |
Coose
| posted on 29/3/06 at 08:05 AM |
As far as I'm aware, my motor has a stock clutch in it. It has had 3000 miles of pretty hard use, including a track day two days ago and is
still going strong!
Don't be so keen to ditch the stock spring until it gets tired.....
Spin 'er off Well...
