kev R1
| posted on 22/4/06 at 01:44 PM |
r1 plumbing
tjis is the header tank i've got, does this need to be higher than the engine or is this just a myth i've been told? also where would be
the best place to put it in the r1 system?
any ideas and help much appreciated.kev
mandbsheldon
| posted on 22/4/06 at 02:02 PM |
Mine is mounted on the bulk head, so is easy to to up etc. It also sits higher than the engine, but don't know if this is a must.
kev R1
| posted on 22/4/06 at 02:10 PM |
cheers leigh was just wondering which pipes to connect it to? post us a pic? hehehehehehe
mandbsheldon
| posted on 22/4/06 at 02:20 PM |
I'm sure there's a diagram some where on here that some one posted, but my top hose to the engine has a T in it which goes to the to small
connector at the top of the header tank. The connector at the bottom of the header tank goes to a T in the bottom hose........ I think
kev R1
| posted on 22/4/06 at 02:27 PM |
are ya sure?
mandbsheldon
| posted on 22/4/06 at 02:32 PM |
no
fesycresy
| posted on 22/4/06 at 02:44 PM |
Search for Oliver Jetson, he's done a diagram of the R1 cooling.
Just about to finish mine and I've the header tank on the scuttle with the bottom connection going to the water pump breather (after the tee)
and the top going to the vent off the thermostat housing.
Hope it's right.
