athoirs
| posted on 22/4/06 at 03:01 PM |
More ZX12r starting probs!
Ok.. Not getting any spark..
Engine turns over ok and fuel pump runs. FI light goes on for one sec then goes out after power up
All the interlocks have been removed ( I think!) and I have a 100ohm res on the gray wire.. (saw that someone put 150ohm in??)
anyone any other ideas...please
athoirs
| posted on 22/4/06 at 04:08 PM |
tried a 150 ohm resistor.. still the same..
pin 20 (LG) on the ECU is at 0v and pin32 at 12v which is right. Could the ECU be "frozen" in a fault mode??
Smartripper
| posted on 22/4/06 at 04:50 PM |
Hello,
Send you a email.
Daniel
athoirs
| posted on 23/4/06 at 07:29 AM |
Got it going this morning..
My mistake (it usually is!) I had extended the wiring from the crank sensor- one of the wires I thought was black/yellow (ground) was in fact
yellow/black (signal)...! give away was the fi light going off and on when cranking the engine!
big thanks For the e-mail it did help. All the info on it is correct
